Use statistics to help you monitor OSPF performance on a VLAN. You can also graph statistics for all OSPF packets.
  1. On the Device Physical View, select a port.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select IP.
  4. Select the OSPF tab.
  5. Select Graph.
  6. Select one or more values.
  7. Select the type of graph.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
Name
Description
VersionMismatches
Indicates the number of version mismatches received by this interface.
AreaMismatches
Indicates the number of area mismatches received by this interface.
AuthTypeMismatches
Indicates the number of AuthType mismatches received by this interface.
AuthFailures
Indicates the number of authentication failures.
NetMaskMistmatches
Indicates the number of net mask mismatches received by this interface.
HelloIntervalMismatches
Indicates the number of hello interval mismatches received by this interface.
DeadIntervalMismatches
Indicates the number of dead interval mismatches received by this interface.
OptionMismatches
Indicates the number of options mismatches received by this interface.
RxHellos
Indicates the number of hello packets received by this interface.
RxDBDescrs
Indicates the number of database descriptor packets received by this interface.
RxLSUpdates
Indicate the number of Link state update packets received by this interface.
RxLsReqs
Indicates the number of Link state request packets received by this interface.
RxLSAcks
Indicates the number of Link state acknowledge packets received by this interface.
TxHellos
Indicates the number of hello packets transmitted by this interface.
TxDBDescrs
Indicates the number of database descriptor packets transmitted by this interface.
TxLSUpdates
Indicate the number of Link state update packets transmitted by this interface.
TxLSReqs
Indicates the number of Link state request packets transmitted by this interface.
TxLSAcks
Indicates the number of Link state acknowledge packets transmitted by this interface.
